PF and VAR
PF and VAR
help me guys what is the difference between PF and VAr mode in power generation?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: PF and VAR
But, controlling absolute VAR production of a generator may not be wise. A large load change with a fixed VAR production may result in the generator operating outside it's capability curve.
PF control is controlling the rate of VAR production in the proper ratio to the load (kW). That is, the VAR production changes as the load changes to keep the ratio between VARs and kW constant.
This may be a case of someone trying to appear knowledgeable by misusing a vocabulary that they don't completely understand.
Bill
"Why not the best?"
Jimmy Carter
RE: PF and VAR
Often you find that VAR control is used in embedded generation on an industrial plant for site wide pF control.
