Air cooled heat exchangers
i just started a job in a manufacturing plant that makes Air cooled heat exchangers and would like to know the step by step process of manufacturing air coolers
Air cooled heat exchangersAir cooled heat exchangers(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Air cooled heat exchangers
Newbie:
It would logically seem that you are in the best career and geological position to advise US of the step-by-step processes involved in manufacturing air coolers. Why do you ask us to describe what is happening in your own front yard?
i will assure you that Mr. Montemayor's response was not meant to belittle you in any fashion.
Perhaps you are imposing limitations on yourself in that you believe that "men wont share any of their mechanical knowledge with" you.
If you demonstrate good mechanical aptitude/knowledge and a willingness to learn, then perhaps the "men in the shop" will gladly share their expertise with you. Certainly, if one presents themselves as incompetent, then you surely can understand such responses from "men in the shop".
Regardless, good luck with your ventures and check/leave the attitude outside the workplace.
Cheers!
-pmover
rmw
Try to figure out what happens at each manufacturing stage. Take note of the manufacturers of the various machines that are used. Go look at their web sites.
Come back here with SPECIFIC questions.
MintJulep is absolutely right. Being able to go out to the shop and see how things actually get done is essential to understanding the manufacturing process. Don't be afraid to ask questions.
Speco (www.stoneprocess.com)
Sales guys always want to tell their customers how great little differences are between their products and the competitors. Many customers don't want to listen to the sales guy, so a sales guy is likely to be eager to find someone who will listen to him.
I suspect that sales is likely to be done through Manufacturer's Reps (or distributors), but a manufacturer always has a sales manager and or a marketing guy in the main office, who should know something about the manufacturing process (my experience is that hard knowledge is iffy for a lot of marketing people).
Dan
rmw
Design, block, cook, fit manifolds, test, paint and ship.
That is; sort out what size it has to be, get the core together, apply some process that joins it all together, connect all the finned pipes together with U tubes or tanks, test it, finish it and send it to the customer.
Exactly how you join it into one lump and fit manifolds depends on the type of air blast cooler. What you making?
I advise you that during the construction in the shop some times the constructers make mistakes because of lack of supervision and misinterpretation of drawings. The bad think that happened to us was, we received an air cooler for a unit, and this air cooler was inspected in shop by the unit licencer. The air cooler was installed in place and after start up we discover that there was something wrong with partition plates the fluid didn't cool because partition plates shouldn't have holes and because of that mistake the product goes in and out without cooling.
For general notes on air coolers go to the site bellow
http://www.stoneprocess.com/acooler.htm
regards
luis marques
