problems with extracting temperature nodal history output in ABQ 6.7
Dear all,
Well,in my last post i was trying to find a soltution so as to edit the inp file , and then running in the command window
I say that  I can manage  and at last it´s work =)
But all of my  inp scripts were editting and making  in ABQ 6.4  with this final sentences
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*El Print, freq=999999
*Node Print,Nset=BALL, freq=1
NT11
*End Step
Now , I got a newest Abq version , ABAQUS 6.7,  so now  I´ll have to do the same work but the script, this version isn`t similar to the scrips that I had in 6.4
this is the scrip without edding it
 OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
*Output, history
*Contact Output
HFLA, HTL, HTLA, SJD, SJDA, SJDT, SJDTA, WEIGHT
*Radiation Output
FTEMP, RADFL, RADFLA, RADTL, RADTLA, VFTOT
*End Step
Could you please help me with that??  I can´t understand what I have to do inside the ABQ enviromental, even though  I made the SET of nodes and , so as to have edit the inp as always. do i have to copy the sentences
NT11
*End Step
 and put it below*Output, history in my new  Abq version  inp
thanks in advanced
paulis =)
RE: problems with extracting temperature nodal history output in ABQ 6.7
After
*Output, history
insert
*Node Output, nset=ball
NT
