Flow control, best method?
I need to balance two flow circuits on the range of 1-10LPM. I was thinking of hooking up two paddle wheel flowmeters to the plc to output to two pwm solenoid valves. So far the 'beans' look like they're going to be adding up to around:
~$300 per flowmeter (X2) =$600
~$150 per sig cond (need 4020mA)(2X) =$300
~$150 per pwm solenoid valve (X2) =$300
As is the case with all of us, I can get more done by spending less. The application is also likely to change scale so replacing the flowmeters and pwm valves each time we size-up will also prove costly. So the two questions I have are
1: Is there a better method?
2: Can you recomend any components or manufacturers
(Been looking at GEMS, ACROMAG, and ASCO as oems
RE: Flow control, best method?
If you just need to batch equal amounts into a tank you could just count the pulses from the paddle wheels and use two solenoids
Roy
what are you trying to achieve? is it a mixing/ratio control problem, are teh streams going into a tank or are they mixing in line. All these will affect the answer.
Cheers
Mark Hutton
htt
& Weidmuller signal conditioners.
ht
I think they are less expensive than what your budget is. I'm not sure who makes a good pwm solenoid valve for cheap.
The gas volume generation varies and ends up providing a bias from one side to the other. We want to control the ratio of these two outputs without going fixed orifice or needle valve because of scaling, and suspended solids. We don't want to filter the liquid.
Stripping out the gas helped a lot but the reliable ratio control across a variable flow range is still what we're trying to accomplish.
Keith Cress
