Blanketing of Boiler Feed Water Tank with Floating Balls?
I am currently doing a study for an economical way to blanket a 5,000 M3 Boiler Feed Water tank. The tank doesn't have a blanketing system at the moment, and is atmospheric tank breathing to air. Therefore the plant experiences corrosion problems caused by the dissolved Oxygen in the water which was introduced by contacting with air at the tank.
The usual way to improve this, I think, is a Nitrogen Blankeing System. But someone says he heard about using floating balls in lieu of N2 Blankting system. To a little bit more explain this: to add floating balls on top of the water in the tank by a few layers, and this floating balls reduces the contact of water with air and thus serves as a simple blanketing system. If this works it will be much cheaper than the N2 blanketing system to operate.
Does anyone out there hear about this? or know anything about this?
It sounds like to work, but it does not completely prevent air contact and thus still have some Oxygen dissolve into the water. Then the question is how much will be the Oxygen content, or by using certain floating balls how much contact surface will be reduced in percentage?
HTech01
HTech01
RE: Blanketing of Boiler Feed Water Tank with Floating Balls?
The effectiveness of the balls is also a function of the diameter of the balls.
Can you explain a little bit more?
Do you know how the performance was - reduction of dissolved oxygen or reduced corrosion?
How much layers did they used?
Htech01
Why not just pour some oil on it? Just be sure to never pump it all the way down. See the tongue in cheek......
rmw
rmw
I don't think pouring oil will work. Because the oil will dissolve into water even very small amount, and that is not acceptable to boiler feed water.
Having balls floated on the water surface will definitely reduce surface area of air-water contact and thus reduce the oxygen dissolving rate into water. So I have no doubt that it will have positive effect. The question is how much!
Also in either case, oxygen will only dissolves up to the saturation concentration at that temperature. And if the water residence time in the tank is long enough to go to the saturation even at the reduced surface area with floating balls. That is my doubt.
So I am wondering what's the result in the actual applications.
By the way I have mistaken about the water temperature in the Tank. It is actually quite warm at 80deg-C.
Waiting more advices and comments,
http://www.euro-matic.com/hollow.html
http://www.paradisenw.com/bird_ball_cover.php
http:
ht
Thank you so much.
These are exactly what I am looking for.
Htech01, this is a very interesting question, as we have some open water storage tanks that we use for testing, and have been dosing for corrosion control. Would be interesting to see if you come to any conclusions regarding your question. Could you please post any conclusions you reach here?
It will take some time before I come to the conclusion, around a month.
But I will definitely post my conclusion and rationale later in this Thread.
I think this is the clue of that method. Without it the balls will rotate, (i.e. in case of pin pong balls) and if so, each ball will be covered by thin water film, perfectly expanding the exchange surface, and thus, extending the oxygen and carbon dioxide dissolving process.
If your water already is 80C... well, it's not far form old type degasifier, where steam at 105C was bubbling through the water.
The water entering the tank must be deoxygenated or the tank dosed with an oxygen scavenger. The floating balls only reduce the surface area exposed to the atmosphere which limits the rate of absorption of atmospheric oxygen. If the water in the tank is saturated with O2 the balls won't help.
Don't try this with ping pong balls, use HDPE balls. DI water is very corrosive and may attack the ping pong balls. HDPE is virtually immune to this type of corrosion.
I found some vendors for these balls.
The material used for the balls are usually HDPE, PP or PVDF depending on the temperature and application.
But I think the nitrogen blanket would be more cost effective than the steam blanket.
The reason:
For steam blanket, I am thinking to purge steam from the bottom. Even so, to make the steam blanketing to be effective - to prevent air leak from outside - I have to maintain the positive steam pressure inside the tank which means I have to feed enough steam to maintain the temperature above 100deg-C. Considering the tank operation temperature of 80deg-C, I have to feed a lot of steam.
Any comments?
A roof does the same thing as the floating balls, but eliminates the water surface exposed between the ball circumferences.
Most tank manufacturers can add a floating roof to an existing tank. It will cost 2-3 ft of tank volume to add one.
http:/
Floating balls has been widely used conserve heat in open tanks. However, floating balls will not be effective for this application, especially when one is trying to maintain ppb oxygen concentrations.
In the applications that use floating balls, the tank fluid level is a constant. The tank water level is not a constant in a boiler feedwater tank. When the boiler feedwater tank water level drops during operation, the exposed walls of the tank will be covered with water. Once the water has absorbed the oxygen and carbon dioxide from the air, you will have the tank corrosion that you are trying to prevent.
You also will have a problem when you lay up your unit. How do you propose to keep the oxygen out when the tank is drained?
Adding the balls to the tank would also provide a place that will allow microorganisms and crud to accumulate.
My two cents..
gr2vessels
