a long conveyer (carriers) ,drive that use more motors
a long conveyer that use more motors instead one :for example instead one motor of 100 kw we can use 5 of 20 kw (a system that we call polymotor if i'm not rong)my question is if the motor is between the two ends of conveyer how can this motor trigger the conveyer.
with rgards
RE: a long conveyer (carriers) ,drive that use more motors
o.k ,i'm not interesting in the linear ones ,if you have used multiple motors connected to a single drive so if this drive is a conveyor ,how the motors would looks ,precisly works, on the middle of conveyor for example how can they participate in drive .and can i see how this conveyor multiple motors looks .(on the internet firm that build such drives).
with regards
please can you show me for example (by shematic figure if it is possible) one motor on the middle of conveyor how can it move(trigger)the belt.
http://www.startco.ca/conveyor.pdf
http://www.cemanet.org/BBChanges.pdf
Usually, a long conveyor or a conveyor with some angle somewhere, perhaps in the middle, lends itself for another motor propulsion. The clue is to have an adequate friction to contribute enough to the conveyor belt motion no matter where additonal propelling motors with rollers are located.
