LATERAL TEE 45 degrees - 6"x6" SCH80 (WPB)
Somebody can help me where can I find this butt-welding fitting in the market Europe/US (LATERAL TEE 45 degrees - 6"x6" SCH80 (WPB))?
And what are the Standard Codes that governs this special fitting?
Is there any problem in place of it use a Latrolet 6"x6" (XS) - SA105 Material?
Luís Grácio
Mechanical Engineer (Energy Solutions)
Portugal-Setúbal
RE: LATERAL TEE 45 degrees - 6"x6" SCH80 (WPB)
http://www.unitedstatesfittings.com/laterals.asp
1. Do you know if there is any possibility to replace the item above Lateral 45 degrees by a Latrolet for 45 degrees lateral branch connections 6" x 6" SCH XS - Butt Weld - Material SA105.
2. What is the code of design and construction that governs the item above Lateral 45 degrees?
Luís Grácio
Portugal-Setúbal
Who will be responsible for the pressure design or qualification of these non-standard XS fittings ? In all piping codes either the fittings are dimensionally the same and burst tested (ASME B16.9 methodology) OR..... there is a unique "area replacement" calculation doe for the fitting at the design temperature and pressure.
How do you know that the unique fittings you purchase will meet the design code ???
-MJC
2. I'm a piping designer, working as a contractor at a "Big Oil" oil refinery. I design to the company's piping specifications. So, I can't help you much when it comes to code details but I would think that you would be looking at pressure piping code ASME B31.X?
Sorry I can't be of more help.
Consult also my previous similar forum topic,
you can find it writing "30"x30"x45 Degree TEE" or following this link
http://www.eng-tips.com/viewthread.cfm?qid=232635
Hansito
