V5 R18 SP7 HF6 crashing issues
I'm having alot of trouble with catia crashing instantly without any warning.  I've only been using 18 for 2 days.  Is anyone else having any issues?  I run a Dell 64bit machine.
RE: V5 R18 SP7 HF6 crashing issues
Did you load 32 or 64bit Catia?
I loaded 64 bit catia
Sounds strange, I run 64bit catia on 64bit HP XW station and I find it more stable then a 32bit. Could you give some more information? which Dell station is it? Which OS? Have you run windows memory diagnostics?
I am running XP Professional x64 on a Dell Precision WorkStation 690.  I have found 1 of my files were corrupt which was causing most of the issues.  I'm having much better success now.  Thanks for the help.
I run the Dell 690 as well.
Did you run Software Management from the Start menu in windows.  Use the Check Integrity tab and Level 3
Derek
I've never used that funtion before, when I go to that page tab, level 3 is greyed out.  What exactly does it do.
