Library from Autocad to Keycreator
Hey,
Is it possible to export an entire library from Autocad to Keycreator?
If so, it would save me a lot of time.
Grtz
RE: Library from Autocad to Keycreator
KeyCreator has a batch translator, and can translate dwg and dxf.
Thanks.
Is there a manual somewhere so I can follow the correct procedure? I don't know how to begin at this task.
Grtz
What are you trying to import?  Library of what?  If you want to import a large collection of DXF or DWG files then choose the "batch translator" option in the "file" drop down menu.  The rest should be straight forward but 100% success is not always certain.
Yes I want to import a library from AutoCad into KeyCreator.
When all the drawings are imported, can I set them in a sidebare or something so I can use them easily.
Gr
Andy
Yes this can be done.  Check with your local dealer for a demo on how to set it up.  Basically it's done by setting up reference files.
