Material suggestions for spherical bushings
These are my parameters.
Corrosion resistant
Actual stress through design is low, but there is a contact stress that could cause deformation. Materil Rc40 and harder solve this.
I was looking a stainless steel type material that can be heat treated to Rc 40 min.
I was looking at 440C
Is there something else I should look at?
Corrosion resistant
RE: Material suggestions for spherical bushings
http://w
Nitronic 60 also makes a good spherical bearing though it is not Rc 40.
a reference from copper development association is given below
http:
I have not failed. I've just found 10,000 ways that won't work." — Thomas Edison
_____________________________________
Beyond that, we can't answer your "What about..?". You haven't told us the size, the loads, the stress, or anything about the corrosive environment.
Mike Halloran
Pembroke Pines, FL, USA
