How to delete notes on surface
Hai
I am using NX5, I have a small assembly, When I copy some surfaces from assembled components by wave geometry linker--Face, I get some texts on all the linked face surface.
I cant select, when zoom out i can see only this bigger texts only( texts hide my surfaces)
How to remove this texts from the surfaces...
thanks for your reply
Rafi
RE: How to delete notes on surface
That will prove what it is and possibly solve your problem. If you select a solid or a sheet body and using MB3 access the Properties settings then under the general tab you van define the object name. You can also delete object names if you wish by selecting any number of geometric entities at once.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Hi Hudson
Visualisation and under the "Names Borders" tab click "Object Name Settings" to off.
it worked out
Thank you...
Rafi
