Anchor Bolt Design
Anchor Bolt Design
Anyone know of good supplemental work book for anchor bolt design into concrete in conjunction with ACI 318 design guide? Thank you.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Anchor Bolt Design
In theory, you should use Appendix D of ACI 318. I suggest using ACI 318-08, as it has some updated provisions on how to take into account the contribution from reinforcement.
But if all you're looking for is a safe and dirty way to design anchor bolts for tension and shear, then AISC DG1 is probably the best way to go.
Both the info and program reference some of the above-mentioned standards.
I have no affiliation with Hilti, I've just found their support products very helpful.
According to metal building suppliers,
anchor bolt diameter
anchor bolt number
and anchor bolt layout
can be and is usually specified by them. but, if you need a recommendation when the bolt is wrong.... you need to get the footing guy to sign off on it because they don't design anchor bolts just the frame.
i guess i'm glad i took the geotechnical exam
by Rolf Eligehausen, Rainer Mallée, John F. Silva
