PDM for a Small Consulting Organisation
This has probably been asked a few times....  What options are available for a small (1-2 person) consulting organisation, which has a large amount of data (engineering reports, drawings, technical manuals, references, correspondence, etc.).  Because of the current work volume (very limited) we need to be frugal, however, a suitable solution is sought.
Thanks.
Randall Shelaga C.E.T.
RE: PDM for a Small Consulting Organisation
I haven't ever used it personally, but I have consulted people on the use of Design Data Manager.  My clients had already chosen it and needed help getting it set up.  I was able to talk them through the main points via phone and email.  By that measure only, it must be fairly easy and I hear relatively affordable.
http://www.designdatamanager.com/
--Scott
http://wertel.eng.pro
Aras Innovator might fit your situation, although I've not used it personally.  The price fits your requirements...
www.aras.com
I recommend you check out Omnify PLM.
I've been using it for over 3yrs. now.
It's easy to set up and maintain. No need for expensive consultants.
Good luck
