Selecting surfaces for contact interaction
I created a screw in bone block model. The screw has a helical thread on it's surface and the hole in bone matches the surface of the screw.
I am trying to create a surface to surface contact interaction between the screw and bone but I do not know how to select the "whole surface" of the screw and the corresponding surface inside the hole in the bone block. When I try to select surfaces individually it only selects part of the surface or the thread but not the whole surface and I end up having errors.
Any help is appreciated
RE: Selecting surfaces for contact interaction
Rob
corus
