Degrees minutes seconds in sketcher
I am designing a part and some of my information is provided to me in Degrees Minutes Seconds.
Can I input this directly into the sketcher dimensions? or do I need to convert it to decimal degrees first?
What is the syntax?
J
What is the syntax?
J
RE: Degrees minutes seconds in sketcher
If there is a way to enter the angle in degrees minutes and seconds I would be very interested to hearing it from somebody else.
Degress+(mintes/60)+(seconds/3600)
Double check my math, doing this on the fly.
For example:
40degrees20'50"
you would use:
X=40 + (20 * 1/60) + (50 * 1/60 * 1/60)
33 + min(45) + sec(22)
I think that was the format. When I tried it in NX4, I got an Invalid legacy expression warning.
Ben Loosli
