U-Bolted Steel Splints
Has anyone encountered or designed a steel splint such as an angle or channel u-bolted onto solid round diagonals of towers? How do you justify the "2% of axial load" lateral support of the diagonal against buckling with this type of configuration?
RE: U-Bolted Steel Splints
Not sure of what configuration you are considering.
One of Timoshenkos references describes column buckling with a larger cental section in the pinned column.
Not sure if this is helpful. More information from initial entry may be in order.
MPaul
SCL
You mention that you are not sure of my configuration. I thought my initial post explained the cross-section that I encountered?
VOD
