AutoCAD 2000 / monitor display
I've been using full blown AutoCAD 2000 for the past 7 years. I've gone through several PC upgrades and crt monitor upgrades with out issues, until now. The IT dept. just upgraded me to a wide screen flat panel and the display (only in Auto-CAD) is distorted. Pre windows Auto-CAD (rel 9) had a monitor calibration capability. Does anyone know if this is still possible in 2000?
Hugomeister
RE: AutoCAD 2000 / monitor display
There's almost certainly an aspect ratio compensation factor in the monitor's auto-adjust. They won't call it that, but it rearranges individual pixels from a 4X3 ratio to one corresponding to the shape of the NATIVE RESOLUTION of your monitor. Run that. It looks like your monitor shakes a bit and settles down.
If that doesn't do it, check the monitor manual for any hard settings that will result in the same thing. Its NOT a setting you change from your keyboard- its a monitor menu change. Use buttons on the monitor. I just experimented 'til I found the right settings on mine.
3rd thing to look into- in your screen resolution settings (right-click mouse on desktop and select properties) . Choose any setting that DOESN'T show a ratio of 4x3 (your old monitor aspect ratio). For instance 1024X768: 3/4ths of 1024 is 768. Find out your monitor's native resoution, and choose a screen resolution that has the same ratio. This should round circles and square squares.
Post back with your final solution- there's likely lots of folks " just living with it " !
Good luck!
Hugomeister
