about chiller feeder
hi, i was informed that hospital's chiller manufacturer wants a feeder size for feeding of about( its load is 100 KVA)) 120 mm2 (underground cable which has a capacity of 170 ampere,) İ calculate that a 120 mm2 cable has a capacity of 320 Amp and it is too much and i guess a cable of 50 mm2 is enough roughly, pls tell me why this chiller feeder is asked too compared to a simple calculation.is it about starting current? if so i know thay NEC wants minimum %125 size cable on the basis of the load value.but why this chiller feeder needs ABOUT 5/2 of the load ampacity?...
RE: about chiller feeder
More data please -- voltage, phase, length of feeder, is the chiller reciprocating or centrifugal, etc...
Thanks and good on ya,
Goober Dave
If it is broken, fix it. If it isn't broken, I'll soon fix that.
How did you "calculate" 320A ampacity?
What does manufacturer of the cable say about the ampacity?
What type of cable? Cu or AL? 3-conductor with armor and PVC jacket? Singel conductors?
NEC or not you need to size 125% of the continuous current. Do you know your local codes?
- There are more cables in proximity
- You also derate your cable when the temperature it is expected to be laid in is higher than its temperature rating.
- the kind of laying used (duct or tray; direct burial)
I don't know how it is with IEC but see NEC 310 for the recommended derating factor.RE: about chiller feeder
