ASME Sect. VIII - Flange Calcs
1) If I run the Sect. VIII appendix 2 calcs on a standard B16.5 flange, can I use it for a higher temp/press rating? Vessel design conditions are 200psig & 650°F, but B16.5 says that for a 4" flange (SA-105) at 650°F the pressure rating is only 125psig. I have done most of the calcs by hand and all looks good. Any thoughts?
2) Does anyone have a Mathcad or excel doc to plug the numbers in to do flange calcs?
RE: ASME Sect. VIII - Flange Calcs
wouldn't it just be easier to use 300# flange.
If I were building this vessel, I certainly wouldn't go to the trouble of checking the flange w/ ap 2
Thanks for the help.
Of course, I guess that you could find the flange that does fail the Appendix 2 calculation, and then you would have "proof' to change the Product Manager's mind.
Always use the worst case gasket seating stress in calculation as someone will use this type gasket.
If you are pushing the limits of a flange you are asking for trouble as someone will tighten the flange until "cups" and leaks. The scenario is normally a small leak and someone over tightens the studs to stop the leak and gets a bigger leak.
h
You get a 24 hour free trial.
