UG NX4 DRAWING VIEW PREVIEWS
WHEN INSERTING A BASE VIEW ONTO A DRG SHEET THE DEFAULT SEEMS TO BRING IN A RENDERED VIEW UNTIL THE VIEW IS POSITIONED ON THE SHEET - ON LARGE ASSY MODELS THIS CAN BE A LITTLE FRUSTRATING DUE TO VIEW REGENERATION TIME - ANYONE KNOW THE LOCATION OF THE SETTING TO DISABLE THIS RENDERED PREVIEW ?
RE: UG NX4 DRAWING VIEW PREVIEWS
In the drafting application use Preferences>Style, and under the Preview tab change from shaded to wireframe.
It doesn't seem to be a remember setting from session to session in NX-4 so go into the File>Utilities>Customer Defaults, under Drafting>General and look for the Preview Tab you should be able to change it there. If the System Administrator is BOFH
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Did you not mean Preferences > Drafting > Preview > View Style?
Best regards
Simon (NX4.0.4.2 MP4 - TCEng 9.1.3.6.c)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by those extraordinary times when it's taken away...
