Adding center marks
Adding center marks
Adding center marks
Basic question, but how are center marks/center lines added to drawings?
RE: Adding center marks
Have a look at the attached PDF.
Click on the show/erase button. The image I have shown is not too clear, the button looks a bit like a torch(flashlight).
You will then see a window showing the type of features that you can show or erase. Move the pointer over each feature icon to get find what each button does.
You can then show the dimensions, datums or C' lines by view, feature, part or a combination.
The feature must have a datum axis shown in the model in order to show it in the drawing.
'hope this hlps a little.
Adrian
You can also make center marks at the center of extruded arcs in sketch mode.  These can be shown in drawings the same as above.
