effect of low gas pressure on burner
I would like to know what you guys would expect to see if you pulled the burner out of a boiler or furnace that had been operating on low gas pressure over an extended period of time. Would it be damaged in any way?
I do not want to sway opinions, so I'd like to get a few responses before I elaborate on my problem.
Thanks.
Thanks.
RE: effect of low gas pressure on burner
Take the "V" out of HVAC and you are left with a HAC(k) job.
