Water Pressure Control
We have a situation where there is about 10 labs that use condenser water. One lab usues about half of the water requirements. We piped in a manifold system with a VFD pump to maintain a 50 psi pressure. Later they told us that every lab needs to have constant pressure (plus or minus 1-2 psi). But when one lab is running and another one starts the manifold pressure dips until the VFD can catch up. This causes instrumentation problems and they can't fully test their equipment. Is there anyway to stabilize the pressure without adding a seperate pumping system for each lab? Would a pressure reducing valve at 50 psi at each lab entrance stabilize the pressure enough?
RE: Water Pressure Control
