Bitmap In Drawing Template
We've got a bitmap logo inserted into our drawing template. The .bmp file is located within our Inventor Project, so Inventor should be able to always find it. However, on many of our drawings, the bitmap appears to get copied everytime we save the drawing. Each saved file shares the filename of the drawing with an incremented number tagged on the end(i.e. HS10-00004 1, HS10-00004 2, etc). The result is, our server has about 500 copies of the same bitmap on it. Anyone else run into this and have a fix?<br>
Thanks!
RE: Bitmap In Drawing Template
Ugly fix - vectorise the bitmap and store it inside your template.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
