UGZIPC with NX 6
UGZIPC with NX 6
UGZIPC with NX 6
Reference: thread561-193435: Assembly backup
I have verified that this utility works up through NX 5, but I can't get it to work with NX 6.  Anybody been sucessful with this?
RE: UGZIPC with NX 6
An update on this.   It looks like the tool is there but it is under a new menu called "Orphans" instead of the File->Export menu.
It worked for me in NX6, but I do recall that for one version I had to (in the MEN file) replace UG_FILE_EXPORT_CATIAV5 with a different option from the File->Export menu. I think I had to use UG_FILE_EXPORT_INVENTOR_3D
Specialty Engineered Automation (SEA)
http://www.sea4ug.com
a UGS Foundation Partner
Perfect! thank you. I actually had to replace UG_FILE_EXPORT_INVENTOR_3D with UG_FILE_EXPORT_CATIAV5.
