ANSYS doesn't connecnt 2 volumes
I'm building a camshaft in Ansys. To finish the cam, i want to connect 2 volumes with the VADD-command (or Vglue, the result is the same :-( ) The errormessage says, that i have to change the BTOL-Value. But both volumes are touching themselves exactly. And a BTOL Change also doesn't work. Ive uploaded the logfiles of both volumes. It would be nice, if someone looks at it and would tell me the problem.
Btw. one file should be inserted as iges-file if you try it out.
