Relief valves and blow down combined
I am intersted to know if you have any experience combining relief and blow down valve in a compressor station. The blow down valve is actuated and uses a pilot that is set at 938 PSI, as soon as you reach 938 Psi, valve opens using instrument air and blows the unit. Thanks
