Loading Custom Hatch Patterns
I am trying to load hatch files from StoneCAD. In the past I have been able to take hatch patterns from various sources and locate them in a file within AutoCAD LT, then use them without issue. I have never touched a .pat file or written anything in notepad or word, just simply copied the .dxf files to a file on my computer and was able to use them through AutoCAD LT 2009. Recently I had to reload the software and I can't figure out where I would go to put these hatch files. Any ideas?
RE: Loading Custom Hatch Patterns
Custom Hatch patterns/ PAT-extension file rules:
1. File name and hatch pattern name must be one and the same.
2. One hatch pattern per file.
3. there must be a single blank line at the end of the definition in the PAT
file.
4. The PAT file(s) must be in AutoCAD's search path.
or 5. You copy and paste the code into your *.pat file.
(aclt.pat & acltiso.pat)
You would have only one *.pat file. But do not copy to much patterns into this file.
Kate, what is with thread555-234411: Can't get rid of the imageframes?
ADT 2004
