Working With Datum Targets
I'm working on a drawing & model of a casting and the subsequent machining step. Only some of these points are explicitly tied to physical geometry, the others are just a theoretical point on a surface.
Any ideas on how best to tie these to apply these? I'm having trouble tieing them to a drawing view and getting them to move with it. Should I just make the dimension driving, or is there another way. I'm loathed to put sketches of points in unless I really have to.
Thanks, a slightly rusty on SE KENAT.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
RE: Working With Datum Targets
I would suggest to select the view, RMB -> properties
then select 'DrawInView'. When put there they will
always move with the worksheet's view. You can put some
constraints to them and dimensions as well. For the
dimensions activate a separate layer so that you can
hide it and thus they will not be visible in the view.
dy
I was thinking of creating a sketch in the model of very small X to locate them to, sound reasonable? I was going to put actual datum targets in the sketch but couldn't get dimensions to them to be driven.
KENAT,
hmm, maybe I didn't get the picture. When in 'Draw in view' and
put a datum target (with that function) and dimension the
datum point to one of the edges of the model the dimension
is driven. When the edge I've dimensioned to moves because
of a change to the model the dimension will change.
When the datum target is attached to an edge or the like
it will move with that edge.
Placing a 'hand crafted' datum target and dimension it then
you have the choice of a driving or driven one
dy
Thanks for what you've put though, it kind of confirms I'm not missing something simple.
Ken
KENAT,
If you put anything on this layer it will not show when you go back to the working sheet.
It's common pratice to put some construction in a view - like lines to show the intersction of 2 edges, or offsetting edges to indicate an extent of a surface preparation.
I'm not fully clear on what you want to show - could you provide an example picture?
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Raaden, unless I'm mistaken Dimensions can't be made driving in 'draw in view'. If I'm wrong and someone could tell me how that would be great.
I forgot to say before I'm still on V19 if that makes a difference.
KENAT,
When in 'Draw In View' mode and:
- you draw a circle or a line and dimension it to an
edge of the derived model then this dimension can be made
a driven or a driving one.
- When you place a DatumTarget (by function) in free space
(but inside the model) and dimension it to an edge the dimension
is a driven one. So the DatumTarget will stay on that coordinate
(that's what it is for in this case)
- When you attach a DatumTarget to a (center)Point or an edge
of the derived model it will stick to that edge
dy
If it is possible is there an option somewhere, the button up on the ribbon bar is greyed out.
KENAT,
First: the Option 'Maintain Relationships' is OFF by default
thats's why the button is grayed out. To change click on
Tools --> activate 'Maintain Relationships'. Now it will
work.
would this be a solution to your problem?
Ccreate a sketch in your 3D-model and tie it to the model. On
that sketch place tiny circles say 0.1mm at the locations where
you want to place the DatumTargets later on. Dimension them
appropriate. Rename the sketch so that the purpose of it is made
clear to someone else
Now in draft display that sketch (view's properties) and
in 'Draw In View' place the datum target (Point only) on
the center of the circles. This way the model will control
the position of the datum targets and thus you have a
single point of control.
dy
Thanks for the 'maintain relationships' reminder, that's what I was trying to find, I thought there was something like that and was searching in help for it but found someting that made me doubt myself instead.
KENAT,
