Modeling transformer wounding
I need to model wire wounding around circular core- doughnut with rectangular section. Something like shown in attached picture.
Is there a way to create rectangular helix that will be curved?
Thank you,
Boris
Thank you,
Boris
RE: Modeling transformer wounding
The feature you seek is a sweep of the wire crossection over the path of the winding. The crossection is easy, a circle in the plane where the wire starts, the sweep is harder. You need to make a 3D path for the sweep to follow, offset from the surface of the toroid by 1/2 the wire diameter. Try it without the corner radius at first.
"we are all toroids in the long run"
Hardie "Crashj" Johnson
SW 2008 SP4
Nvidia Quadro FX 1000
AMD Athalon 1.8 GHz 2 Gig RAM
As SnowCrash stated, the 3D path is harder to do and the resulting sweep will probably bring most computers to their knees!
Unless you have a very good reason that demands you model the actual windings, it would be better and easier to just make a solid revolve of the external dimensions. If you need a cross section for a manual illustration, then use a decal/bitmap texture on the cut face.
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2007x64 SP3.0 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2009x32 SP1.0 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.11.7751
Rob
Boris
