SA-212 Grade B Mechanical Properties from 1965 Section VIII
I have seen posted here values of the allowable stress vs. temperature for SA-212 Grade B - here, here, and here
However, I would really appreciate it if those who have access to the 1965 Edition of Section VIII would also post the values of the Yield and Ultimate Stresses as a function of temperature.
RE: SA-212 Grade B Mechanical Properties from 1965 Section VIII
Is this what you want?
I am performing a FFS evaluation of a circa 1965 vessel, and was hoping to use the yield and ultimate vs. temperature data from that time.
I have not seen this type of mechanical property data published in earlier editions of the ASME B&PV Code. For this material I would use the stress line (allowable) published in 1965 and back calculate the UTS based on approximations using a SF of 4. Typically for time independent service, the UTS/4 would govern the allowable stress. For the YS determination, I would graph the UTS/temp and use the same slope to construct the YS/temp curve starting with the published min YS at RT.
I suggest that you use the current ASME II to look up the Yield and Tensile strength values at elevated temperatures of interest using SA516-Grade 70. They should be pretty much the same as SA212-Grade B.
Joe Tank
