SW2009 automatically uses vb 6.0 not vb.net
For some reason when I installed SW2009 on my computer it reverted back to using the same version of visual basic that SW used in SW2008 and before. I thought SW switched to visual basic.net as their main macro editor. I contacted TriMech, which is our SolidWorks distributor but they didn't know how to fix it.
Did anyone else have this problem when they installed SW2009?
RE: SW2009 automatically uses vb 6.0 not vb.net
Did you install the VSTA components?  If you used the Installation Manager they should have installed as a pre-req for SW2009.  You can download the component from the SW website.
Cheers,
Anna Wood
SW2008 SP5.0, Windows Vista SP1
IBM ThinkPad T61p, T7800, FX570M, 4 gigs of RAM
http://www.solidmuse.com
http://www.phxswug.com
jcoult,
You can use visual basic.net to create an executable and use a macro to run that executable.
Bradley
SolidWorks Pro 2009 x64, SP2.0EV
PDMWorks Workgroup, SolidWorks BOM,
HP xw8600,
64-bit Windows Vista Business
Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB,
nVidia Quadro FX 4600 Driver 7.15.11.6956
