Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...You have made an incredible site which is truly a great help to me in solving problems. A tip of my hat to you!..."
Geography
sammy3534 (Mechanical)
12 Jan 09 11:00
I am relatively new to Solidworks...only since last Oct. I am drawing a tension spring. I have drawn the helix. And I have drawn the loop at one end of the spring. but the end of the loop and the end of the helix do not connect. I have trimmed the sweeps for each and I am using 'Boundry' to blend the two sweeps together, but I get an Rebuild error that states there is Self Intersecting Geometry. The blended sweeps preliminary looks good, but it will not accept it due to this error. Can anyone suggest how I can blend the two sweeps together? It almost appears as though I should fillet the sweeps, but I don't think that is possible.
Helpful Member!  MadMango (Mechanical)
12 Jan 09 11:04
The future solid geometry you are trying to build will occupy the same space or volume, IE. Something is overlapping where it shouldn't.
Helpful Member!  CorBlimeyLimey (Mechanical)
12 Jan 09 11:28
Combine the helix and the end loops at the sketch level, and create one sweep along the complete path. Separate sketches can be combined using the Composite Curve function.
cheers
12 Jan 09 11:39
Correction: After creating the helix, Start a 3D sketch and convert the helix into it. Then sketch the end loops in the 3D sketch to create one single path for the sweep.
cheers
Helpful Member!  SnowCrash (Mechanical)
12 Jan 09 14:53
Be careful that the radii are not so small as to pinch the swept solid. That can create the self intersecting geometry.
Hardie "Crashj" Johnson
SW 2008 SP4
Nvidia Quadro FX 1000
AMD Athalon 1.8 GHz 2 Gig RAM
Close Box
Join Eng-Tips® Today!
Join Us             Close
