Ni Lined Piping
Ni Lined Piping
In my petrochemical plant, we have a loop reactor with Nickel Lined piping with Hydrogen contents in high pressure and temp.Service.
Any ideas how Nickle lining is carried out in such piping??
And how one can inspect the integrity of it over a long period of service say around 12 years?
RE: Ni Lined Piping
http://w
These links may be of use.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
RE: Ni Lined Piping
RE: Ni Lined Piping
for clad pipe they bond the Ni to the steel either by rolling them together or by using explosives. Then they form and weld a pipe. The weld pass on the inside is with Ni filler, and on the outside with steel filler.
clad http://www.dynamicmaterials.com/home
pipe http://www.butting.de/bubi-pipe.html
In your case the two big risks are:
1. hydrogen permeation through the liner and causing blistering or the structural part of the pipe. This maybe lead to extensive dis-bonding of the lining.
2. Pinhole leaks in the clad layer allowing corrosion of the structural pipe and possible disbonding of the liner.
Plymouth Tube
RE: Ni Lined Piping
It is a Ni clad pipe...I am exploring a sutiable inspection technique to establish the integrity of lining.
You may appreciate that Inspection from inside may not be possible due to difficult approach in the pipe that is 10" in size. Also i can't do it in running plant.
