Design of welded vacuum chamber subjuect to random vibrations
in my company we have designed and manufactured a stainless steel vacuum chamber needed to perform a vibration test of an item under vacuum conditions. When performing random vibrations at full level, after some time, the weld on the chamber base broke on 180° circumference. What can I refer to for correct sizing of this weld?
Marco
RE: Design of welded vacuum chamber subjuect to random vibrations
It was a fillet weld wasn't it?
Yes, continuous fillet weld.
Fillet welds perform poorly in fatigue because they essentially build a crack into the design.
For fatigue applications full-penetration welds are better.
