Setting a GE T35
Setting a GE T35
Setting a GE T35
I am working with a GE T35 relay, and I'm stuck on how to determine the appropriate setting for Slope 1.  I have a GE document for T60 percent calculations, and it summarizes the Slope calculations as
[(delta Id)/(delta Ir)]*100%
where Id is the differential current and Ir is the restraint current.  Defined as:
Id = i1_comp + i2_comp (shown as vectors)
Ir = max(|i1_comp|,|i2_comp|)
"comp" is never defined, although I assume it means magnitude compensated.
The definition of Slope 1 is the slope setting from pick-up to break 1, and it is based on CT errors during normal load currents and from tap changes.
Okay, so what I want is a clearly written equation for how I set slope 1.  Does anyone have such an equation?
thanks
