How to purge a pasted block
I created a sketch and defined a block in an assembly model. Then I selected the sketch and copied using Control C. Then I opend another part model, selected a face and then Control V and pasted it in. Been doing this often, works well. But then I changed the original block in the assembly model, re copied it went to my part model deleted the copied sketch and block, then pasted in the modified sketch and block but the old one shows up.
How can I purge the block out of a model when it was pasted in.
Tom
Tom Malinski
http://www.okayind.com/
Dell Prec 670, Xeon 3.8,2GB Ram, Nvidia Quadra FX 3450/4000 SDI
SWorks Premium 2008 SP 3.1 & PDMWorks
RE: How to purge a pasted block
Have you tried selecting it and hit the delete key on the keyboard? Or select it in the feature tree?
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Yes, I deleted it completely and saved and closed the file. Reopened the file pasted in the new one but the old one still shows up instead.
Tom Malinski
Didn't try that, I will tomorrow morning
Tom Malinski
