Loads on secondary pipe supports.
Is there any thumb rule, guide line, notings available for calculating the pipe loads on secondary pipe supports (like cantilever brackets, inverted L suppoets, Inverted goal post supports) so that it is sure that the members used for such a supports are safe for such loads (because in the load limits for such supports which are mentioned in the support spec are only on the papers)
Sachin
Sachin
RE: Loads on secondary pipe supports.
Sachin
"Pumping accounts for 20% of the world's energy used by electric motors and 25% to 50% of the total electrical energy usage in certain industrial facilities." - DOE statistic (Note: Make that 99.99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Dead weight does NOT include contained fluid weight - contained fluid weight is live weight (look t at B31.3). Dead weight AND live weight combined is called (just) WEIGHT. This nonsense of referring to all weight as "dead weight" seems to have started in the nuclear business in the 1970's (another example is their calling computer programs "codes") and now the young people coming into piping engineering are blindly following that error. Enough already!!
The olde guy now folds his soap box and steals away for his afternoon nap.
John.
