what is this flanged-sleeve-bearing-like piece called?
Every few months or so, I try to find a piece of hardware that looks like this (that will not function as a flanged sleeve bearing, usually found in plastic or bronze), but I can never find it (on McMaster or wherever). I need it to be steel and small (=~1/4" OD) and it just needs to function as a protective insert in a sheetrock-like material that is tied to other objects with wire. What is this piece called and where is it available? Or what would do the function I described better? Thanks.
RE: what is this flanged-sleeve-bearing-like piece called?
http://cableorganizer.com/richco/snap-bushing.htm
You need to be rather more specific about what you need this to do.
Also you should link the picture since it is breaking the forum format.
Mike Halloran
Pembroke Pines, FL, USA
http://www.stimpson.com/grommet_plain_washer.htm
Ted
