Hole call outs
Hole call outs
Hole call outs
It used to be that when you created a hole in hole wizard as," Up to next" that the call out read as THRU. Now no matter what I do I get the exact depth, that is to say if my block is .750 it reads as a .750 deep hole. Whats worse is that I can not edit the value to replace it with thru. Has anyone else experienced this?
RE: Hole call outs
Yes.  This is a known issue.  Fixed in SW 2008 SP4.
-handleman, CSWP (The new, easy test)
