Info window to display by default when measuring... ?
Folks,
Is there, and if so then where is the setting for defaulting the 'Information Window' to show when taking a distance measurement? When I measure a distance, I'd like the results to display in the information window by default; I currently have to click on 'results display' and then click the radio button 'Show Info Window' for it to display. Any ideas? TIA...
SS
CAD should pay for itself, shouldn't it?
RE: Info window to display by default when measuring... ?
Analysis -> Measure Distance... (or Angle)
...dialog there is now an option at the bottom of the dialog (in the 'Results Display' section) which you can toggle ON to display the results in a listing window after you make your selections. And while this may at first not appear to be all that different then the behavior of pre-NX 5, what's new is that 'Dialog Memory' will now REMEMBER that you toggled it ON the last time and until you toggle it OFF in the future, it will continue to automatically display the results in a listing window whenever you perform a measurement.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
The "dialog memory" will only work if you choose "OK" when you're finished using the measure tool.
If you hit the escape key or choose "Cancel" to end measuring, the dialog memory will not update.
JAY
Also note that in NX 6 if you complete an operation with an 'Apply', even if you then cancel out of that dialog, the next time you enter it, the 'Apply' will be the 'Default-Action' (Green) which you can select using MB2 (Middle Mouse Button) which is generally more efficient since it does not require as much mouse navigation.
John R. Baker, P.E.
NX Design
Cypress, CA
Thanks much. Twas the 'OK' thingy that did it (seems I've developed a habit of canceling/applying and not hitting 'ok'). Anyways, here's your star.
SS
