corrosion protect by nitrogen
hi;
do you know about corrosion protection by nitrogen for steel box section?
RE: corrosion protect by nitrogen
Can you comeback with a little more information about size etc.
Just remember that N2 in an enclosed space is lethal for human exposure.
Unclesyd raises very good questions. The steel box would have to be airtight to keep the nitrogen inside once placed. Also, pumping air out and nitrogen in would be a problem, and certainly inspection would not be possible or very difficult. Besides, if you make the steel box airtight, then nitrogen would not be required to prevent corrosion, just dry the air inside and close the box. No moisture, not rust.
