connect materials to a thickness table
Hello everybody,
I would like to connect materials that I have already created to a thickness table. How can I do that in solidworks?
Sarah
ps. I work with solidworks 2008 but my boss is thinking to upgrade to 2009
RE: connect materials to a thickness table
Hmm. You could do something like that with a part template, I guess. Create a part with the designated material and a table of thicknesses and save as a prtdot. Then whenever you want to use, say, aluminum, for a new part, select the "alum.prtdot" and select the thickness you need from the table of values.
Is that where you're going?
Hardie "Crashj" Johnson
SW 2008 SP4
Nvidia Quadro FX 1000
AMD Athalon 1.8 GHz 2 Gig RAM
