dwf import problem
dwf import problem
While in the DWF viewer, I choose .....import and select a DWG..... I encounter Problems encountered during dwg import.....
Any ideas why?
Any ideas why?
RE: dwf import problem
Autocad 2000 won't import from say 2009??
2009 will usually import from an older version.
After TrueView is installed, "Import" will be available, and then when you chose a DWG to import, it will be converted to DWF and displayed and you can save the DWF.
