Correlation
Correlation
Correlation
This might be a very simple question. I want to know if ANY relatation exists at all between two arrays. A correlation I read determines only if a linear relationship exists. Please correct me if I am wrong about this. I can plot the data in excel and try all the fitting functions and check the R^2 value. But I am sure there are other methods for this. Online search suggests solutions such as copula, correlation ratio etc but I could not find an example of how to implement it. Any help is useful. Thanks
Joe
RE: Correlation
AT the level at which I work the usual trick is to transform x2 so that it is a linear function of x1, and then apply the normal (sorry) statistics to the transformed x2 values
I don't think one exists for the general case where x2=f(x1) and f could be almost anything.
The reason I say that is things like the equation for a circle, where there clearly is a correlation, but no trend.
However I will happily admit that I am out of my depth.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
