Showing assembly sketch line colors in draft view.
I drew a small plant layout in a sketch in an assembly. I used different colors to have a clean view of what is what. Then I inserted some models inside the assembly to position the equipments that will go in the layout.
Until there everything works like a charm. But my problem is when I want to show all of this in a drawing view. I can easily show my assembly sketch but unfortunately the colors won't show, I have all the lines showing with the same visible style.
I would like to see the same colors in the draft view that I selected in the assembly. Is there an option for that somewhere.
Thanks in advance.
Patrick
Thanks in advance.
Patrick
RE: Showing assembly sketch line colors in draft view.
log an ER with GTAC.
Fred
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Thanks guys.
Patrick
