Adding Bend Deduction to the Design Table
I've created a Nema-12 (SGG) box, hinge & cover asssembly.
I've also created a design table for each part to adjust the height, width and length of the enclosure. So far so good. But now I have multiple assemblies and parts for the different Material types and Material thickness. My question is: Can the Bend Deduction Properties be added into the Design Table for changing. Can the Material type Properties be added into the Design Table for changing.If so, what would the lables be?
Thanks for your help.
Les
