Can't get rid of the imageframes
I am using LT2009 on Vista plotting to a Xerox 510.
No matter what the IF setting is 0 or 2 parts of the frame still plot.
They do not plot when using cutePDF writer
What setting in the .pc3 file if any will get rid of the lines?
Also DWG to PDF.pc3 plots too dark. allegedly this was fixed with SP1 for LT2009. Any ideas?
RE: Can't get rid of the imageframes
is the plotpreview ok?
Can you clip the image with LT? Try that, it could be a workaround (_imageclip).
Lothar
ADT 2004
To insert images on a single layer. Open properties->general, the color of the frame is set bylayer; open the layer manager and set the layer color to white or the same color as the image's border.
Keep in mind, with imageframe off, you cannot select the image to move it around or change its properties. To do that, turn imageframe back on.
Don Phillips
http://worthingtonengineering.com
