Paperspace question
Paperspace question
I'm using AutoCAD 2008 and I'm having a problem when using paperspace. I have a drawing that has been very jumpy. By jumpy I mean, in model space when I zoom in and out, it jumps. It's hard to explain. But, when trying to select grips or snap points, it's difficult to maneuver the mouse. It's very agitating. I've tried everything to determine what is causing this.
I've contacted our company that provides customer support, and they think it is a video card issue. However, I don't have this problem with any other drawings. The size of this drawing is only 1.8 MB so it's not overly large. So, that kind of threw out the idea that I had some enormous exploded block buried somewhere in my drawing. Regardless, I swapped out video cards and noticed no change.
The next step, I opened a brand new template and copy and pasted my drawings into it. Everything runs smooth as can be. I have every entity, every layer on the new template and I save it. I think I've solved the problem, until I click on the paperspace layout. All I have to do is click on the paperspace layout and the "glitch" comes back. I thought it was caused when I clicked inside a viewport and zoomed to scale, but it occurs when I click into a paperspace layout. It only does it with this one particular drawing though. I have no problem with any other drawing. So, it has to be a setting somewhere or something within the drawing itself.
Working with the current problem just isn't viable. It's not just uncomfortably glitchy, it's impairing my ability to draw.
Any suggestions?
Any suggestions?
RE: Paperspace question
(I wasn't quite sure if this was happening in paperspace/in a viewport but not otherwise....)
I agree
Rule of thumb is not to nest XREF's more than once. Anotherword dont XREF another drawing that in itself has XRef's
There is no reason not to have multiple copies of an XREf'ed drawing into another drawing.
