small cheap 4 channel data logger
Hi I'm looking for a datalogger. It needs at least 4 analog channels )(more would be better)  in (say 0-10v)(more would be better) sampling at 10 Hz per channel (more would be better), with at least 8 bit accuracy (more would be better) and able to store 2 minutes of data (more would be better)
ideally it would cost zero dollars, say 300 tops. I am willing to build a kit but don't want to have to write my own assembly code.
I have found this rather good thing, but it would need a PIC based computer with a USB to store the data. A rather heavy alternative would be to just buy an old laptop and plug it into that.
This would probably do the whole job, but looks like a long learning curve.
Also, any ideas on cheap latacc and longacc and yaw rate senors?
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
RE: small cheap 4 channel data logger
I watched your post with no replies.  I can't help you directly.
I normally use a PC/Laptop to log the data and there are many ready built and kits that would suit you.  However I assume that you want a standalone unit.  There seems to be a number of these using memory cards or USB memory to log to.
Doing a stability control?
p.s I'm in Australia.
Yes, that's a good ish solution. Frankly I was hoping for something on a single board, but there is a big advantage in having a whole computer to do it on - it is all self contained.
Cheers
Greg Locock
I particularly like the solid state hard drives for such a harsh environment.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers for professional engineers
"Also, any ideas on cheap latacc and longacc and yaw rate sensors?"
You need to look at the hobby robotics suppliers.
www.sparkfun.com has a lot of accelerometer / gyro / IMU options.
Regards, Ian
I just got one of those Asus EEE Pc's that Patprimmer was talking about.
Picked it up used for 200$.  Runs great if you strip off the original linux distro that it comes with (not a fan).  I installed Xubuntu.
If you decide to go with a computer I highly recommend using this if you are comfortable with linux.
